I am following to instructions to extract audio (http://www.vcdhelp.com/divxtovcd.htm#audio) with no luck.
I am using VirtualDub 1.4.10 and when I try File->Save WAV (after all the previous steps) I get this error message:
The requested audio compression is not compatible with the input format.
Check that the sampling rate and channel count of the input
match those of the requested format.
Is there any missing part in the instructions? I've tried it with several Divx files.
Thanks a lot.
WIERD!!!!!! I just posted the EXACT same msg below here somewhere mate! Check it out..
This is usually due to AC3, multichannel (5.1?) or VBR encoded audio in the divx avi. Look to the guides on this site for details on how to handle this.
Problem extracting audio from mkv
By Djago in forum Video ConversionReplies: 5Last Post: 12th Jan 2012, 18:57 -
Problem extracting audio from WMV files
By Bully9 in forum AudioReplies: 33Last Post: 21st Jul 2011, 05:27 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 07:51 -
VirtualDub audio problem
By wcdeich4 in forum EditingReplies: 9Last Post: 10th Dec 2009, 21:57 -
Extracting audio with VirtualDub
By RedPenguin in forum Newbie / General discussionsReplies: 12Last Post: 16th Dec 2007, 19:03
