My friend sent me some VCDs, but I can't watch them on my DVD player. I need to convert them to MPEG, AVI, MOV, or QT so I can burn them to DVD. Anyone know of a program that will do this?
Put the vcd in any cdrom drive>copy the dat file off the vcd> get vcdgear from tools section>open dat and convert to mpg.
I had this program & I believe it only converts to PAL format, anyone?Originally Posted by MaDmiZe
Nope ...It may output pal if your original file is in pal format.
Its just taking the dat and converting back to mpg.....an mpg could be pal or ntsc.
You can also use TMPG for this... then you can set out put to whatever format ya want....but TMPG would have to reencode....that takes a while..
Where as VCDgear takes maybe 5 minutes.
DAT to DAT cutter?
By coxanhvn in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2010, 12:13 -
Empty file when converting vcd (.dat) format to ipod (mpeg4)
By happyriceman in forum ffmpegX general discussionReplies: 3Last Post: 5th Jul 2008, 06:19 -
converting .DAT file to readable jpeg
By illyad in forum ComputerReplies: 4Last Post: 23rd Oct 2007, 05:14 -
Converting .dat to avi
By demonwarrior in forum Newbie / General discussionsReplies: 8Last Post: 20th Jun 2007, 03:18 -
Anyway to fix a .dat?
By demonwarrior in forum EditingReplies: 2Last Post: 19th Jun 2007, 05:30
