I have a Pioneer A04 burner .It is stuck on REGION 1 play back.
Will it alow me to make REGION 2 discs??? ( I live in UK)
Will harm any DVD I Burn.
Will it make them Region 1 ???????
How can I change the region.
Thanks rob
OK, first you need to understand that playback and record are two different things. When you burn DVDs they are REGION 0 which means they will play in ANY DVD player no matter what the region code is. (so long as they will play DVD-R)
To change the region code you need to goto CONTROL PANEL and then SYSTEM. Then find the drive and click PROPERTIES. There should be a tab for the region code. Keep in mind that you can only change the region code a maximum of 5 times. (including the original setting) If you have changed it 5 times already, then you are out of luck.
Regards,
Savant -
go her http://www.firmware.fr.st/ and get the RPC-1 firmware no more region lock
ChRaN :-)
pioneer dvr-433h stuck on 'load' and can't operate any buttons!!
By Scubatt in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th May 2010, 03:07 -
PIONEER-610AV-K region problems
By matt2112 in forum DVD & Blu-ray WritersReplies: 8Last Post: 28th Aug 2009, 16:18 -
Region problem with Pioneer
By bltprf in forum DVD & Blu-ray WritersReplies: 10Last Post: 28th Jan 2008, 05:36 -
Pioneer DVR K-17 Region Hack
By d1sc0_dave in forum DVD & Blu-ray PlayersReplies: 0Last Post: 29th Jun 2007, 17:46 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
