Does anybody have any pointers on how to rip just the movie and audio (no extra features) of a dual layer dvd so I can burn it to a DVD-R?
Results 1 to 15 of 15
Try using yade. It allows you to preview what you are ripping so you can get exactly what you want.
I tried YADE and couldn't get it to do a damn thing... nice layout though... but when I would clip on the files... it would shut down
I had the same problem with Yade, so I stopped using it. Now I can't find where I downloaded it from, and it's driving me crazy! I want to try it again since I installed a fresh copy of OS 9. Is Yade most effective in OS 9.2.1, or a different version of 9?
I'd like to try it again because it has that preview feature that DVDExtractor doesn't. -
What about OS X and Classic compatibility?
Yade will only work in OS 9. It doesn't work under OS X. For the yade download goto http://www.opuscc.com/download/FTP/yade.sit
Is there a way to reduce the quality of the vob files without having to convert them to m2v or mov?
Very doubtful. Vob files contain more than just one segment of the movie. vob files are more like .sit files and contain everything together. Thus a vob editor would have to be able to decide which vob to edit and when to combine vob files and etc. I think you're gonna have to convert.
Sorry I don't think there is one. If you want to reduce the size of it you'll have to convert to .mov and do all your compression there. I believe then that DVD Studio will allow you to import your .mov file and burn it to the DVD-R.
Media pipe for osx can take a m2v and spit a smaller sized one. When using the mpeg encoder select svcd and type in whatever bitrate you want. Like so -b 2500. anything higher than 2500 will not be a standard svcd if you go that route. Make sure you look at the options to see other settings are set as you desire.
Well what I want to do is almost the same as you "Aneuploid". What I would love to do is take out the specials on some dvd's and burn the dvd with a modified menu. I need a good tuturial to show me how to rip a dvd and modify it to my needs. After that burn the files on a DVD-R and play it on my DVD reader. I tried looking at the tutorials on this page but they have them mostly for pc's or vcd's. I don't want to make a vcd or svcd but I want to come as close as possible a DVD. Can anyone point me on the right direction with a tuturial that actually helps and not confuses you to no end...Any information would be very usefull and thanks in advance.
here is a link for a good tutorial on buring dual layer disks:
http://www.macdvd.org/ubb/Forum1/HTML/000079.html
this is a vcd forum so there isnt much to find here on dvd burning. here is a good, general place to start, that covers everything from vcd-dvd. they may be able to answer some of your questions here:
http://www.macdvd.org/cgi-bin/Ultimate.cgi?action=intro
i hope these sites can help u out!
what software do u use for burning you dvds? i only have iDVD (i've only had my mac a week) and i ca nrip the contents of a dvd, but dont know how to burn it? iDVD is a bit cack really. O and how do you pay the files from the HD? forgive my n00bience but i kinda want to take advantage of my superdrive, and back up my dvd's
Burning AVCHD File To Dual Layer DVD
By Falco21 in forum Authoring (Blu-ray)Replies: 4Last Post: 15th Mar 2011, 12:16 -
Burning 720p Avi. Movie to Dual Layer DVD
By Falco21 in forum Video ConversionReplies: 2Last Post: 28th Feb 2011, 15:06 -
Dual-Layer burning of DVD using nero?
By mr_jbloggs in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2008, 08:26 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
Burning dual layer dvd-r from mac the ripper
By alforra in forum MacReplies: 11Last Post: 18th Apr 2008, 22:08
