  1. I convert the video off of my DV camcorder to AVI (raw). It is always darker than what was on the camcorder. If I use tmpegenc and load videocd_NTFS.mfc it will convert nice, but it is so dark I can not see it. If I load the same videocd_NTFS.mfc and choose custom color in advanced and select basic color and change the brightness to were I can see it the video is choppy and the audio sounds like it was slowed down to more than half the speed. So much that I can not even understand it.
    Any suggestions from anyone on how to fix it or lighten the color so I can see it? Any help is much apprectiated.
    Cris
  2. Leave everything to 0 and try increasing the 'Gamma' hehe, maybe ti work
  3. After reading your reply, I did try that at it made it a little better, but far from good.
    Any other suggestions. I do have a AMD 1ghz with 512 ram and running win 2K.
    The thing that throughs me is that if I do not do custom color config it is great, gust dark.
  4. k one more try, you can edit the AVI in VirtualDub before you even encode, the drawback is u have to reencode the AVI then encode to VCD, or you can frameserv from VDub to TMPGEnc
