Greetings,
I have read threw the All-in-1 guide(+links) and the 'best way to convert 320*240 low bitrate divx to vcd'(320*240 source to 352*288 output) docs. I have a question on aspect ratios going the oppisite way. Have a 352*288(PAL) source that I want to convert to 320*240(NTSC). I have tried and played with the suggested aspect ratio settings but have noticed that the MPEG output in this mode 'crops' the video output on my TV->(Philips DVD701).
Any suggestions from the 'gurus' regarding this scenario and possible fixes? Totally green at this stuff (2-weeks) and trying to play catch-up.
The source aspect ratio must be 1:1(VGA) presuming it already has correct aspect ratio. Video arrange method must be Full screen(keep aspect ratio) if you want to make sure you see all of the picture. And you may find NTSC(film) VCD template gives better results because the framerate difference is less.
PAL converted from NTSC source - Ghosting and interlacing
By OngekibouRekka in forum Video ConversionReplies: 7Last Post: 3rd Dec 2011, 12:20 -
Video in PAL and Audio from NTSC source
By jairovital in forum Authoring (DVD)Replies: 30Last Post: 17th Jun 2010, 13:16 -
IVT with AVISynth of source that has both PAL and NTSC conversions
By csdesigns in forum Video ConversionReplies: 9Last Post: 10th Feb 2009, 13:15 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 14:39 -
Converting to Divx and Aspect Ratios
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 28th Mar 2008, 17:43
