I have a 1.40 hour movie in avi. If I go to moviefactory and use make movie and set the MPEG2 setting it will convert but only 12min. and then stop. Why? how do I do the rest of my movie?
Danie![]()
When you say it stops, does your system hang or do you just get a 12 minute mpg? I found that Ulead DVD MF would hang or freeze up, and in each case, it was attributable to bad frames which I could later locate with an editor, like Virtual Dub. Check the integrity of your AVI.
Hi thanks, it stops because it will only allow you to convert, well to be more corect, 9min 56sec. 06 frames. And thats it. my PC works fine and then from there I could just continue with burning. How do I now convert the rest of my Video.avi. ?
Danie -
I found my problem. Just for the other readers interest. It was Adobe Premier. It convert in a differnt codec than all other softwear so you cant write to DVD sucsesfully.
thanks
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 13:42 -
Ulead DVD Moviefactory 6 Plus (trying to get to grips after UDVDWorkshop2)
By dvdfever in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2009, 20:01 -
Joining in Ulead DVD MovieFactory - does it lead to worse quality?
By rosbif08 in forum EditingReplies: 2Last Post: 6th Aug 2008, 21:32 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 10:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 10:46
