Ok i'm trying to put some of my VCR tapes to MPEG1 and then to VCD (since my SONY DVP NS 300 doesnt support SVCD)
Ok i have capture my files and edited them nice using Intervideo software.
Saved them as MPEG1, Convert them with TMPGEnc into MPG and then i use Nero 5.5.8.2 to burn it on a CD-R as VCD.
I have a DVD player in my computer and it works on that one.
My standalone DVD player SONY DVP NS 300 somehow deosnt like the CDR's. Tried using CompUSA CDR 74 mins and SONY CDR 80 mins Jewel but no luck.
Any help is welcome
Not all standalone DVD Players play VCD's.... You can check on the left bar under DVD Players.
If it does read the comments. SOmetimes only certain types of CD-R/CD-RW's work... -
IT does support VCD according to the DVD list here and also on the DVD player it self.
Well, that is probably your problem...
If you really want to watch them on TV use a TV-Out or go buy a new DVD Player....
Apex has cheap ones that supports a lot.
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Multi-System VCR (Panasonic NV-SD230) - Some quick questions
By quantass in forum Newbie / General discussionsReplies: 0Last Post: 18th Dec 2008, 00:47 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02
