Can you burn any type of MPEG to a Video CD? Like lets say I have a DVD quality mpeg and I don't have a DVD Burner. Can I make like a 8 disc Video CD?
Well you could split it into 8 CDR's if you wanted too..
but most people use 2
If you have a DVD quality Mpeg, and its 80 minuets long, then it will fit on 1 CDR (VCD) you only need to split them if they are over 80 minuets. -
who'd want to watch a movie that you had to change the discs on 7 times?
changing 3-disc svcd's is bad enough..
if you're looking for "dvd quality" mpegs, you can get amazing results ripping a DVD and encoding to SVCD, mpeg-2. you can get about 40 minutes on a disc that way.
check the links at the side of the page, they'll help you..
-MarkSwim with me
And we'll escape
All the trouble
Of the present age
Finally free -
You can get 90 minute Disc's but even then the amount of disc you have may put people off watching it. Perhaps you should reduce it too around 2/3 discs. This seems to be the max people will put up with
Smithy
Gosh, you lazy lot....
You have the latest block buster movie, and don't want to get out of your chair to change disks. 8)
Why don't you invest in a good disk changer then... ? I have one, all I do is shout "Change the disk" and the wife changes it
Na, all you need to do is modify what I said for it to work.
Change the disk, please
Change the disk, sweet heart
Change the disk, or else !!
Change the disk, and Ill buy you a new dress/diamond ring (Always works)
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 19:49 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 18:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 02:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 14:13 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 19:33
