I've got 8 gigs (38 minutes) of Drag Racing captured onto to my HD from my digital camera (ZR-20). I can play the video directly off the hard drive with media player,it's perfect. But converting it to mpg (DVD) the audio is very muffled, the voices sound like it's in slow motion, although the engine noise sounds good. I'm using Tempg. Help.
jim
Go ahead and check the guides on the left side to make sure all your settings are right, then if you still have problems let us know some specifics about your encoding situation (bitrates, etc)
calamari -
Are you converting it from DV AVI - to AVI - to MPEG? if so why not just convert DV to MPEG.
Ok - you got me - i dont know anything - you happy now! -
Well, good question the capturing software changed it to AVI.. but there really is no requirement.. the end reslut for me is DVD-R anyway...
Thanks for the input!
Jim
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 20:20 -
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 22:34 -
Having trouble using DVDx to rip to .mpg or .avi
By waldothewonderboy in forum DVD RippingReplies: 19Last Post: 30th Aug 2010, 03:48 -
Trouble converting VOB to AVI using Handbrake (audio issue)
By binvisions in forum Video ConversionReplies: 1Last Post: 1st Aug 2009, 03:28 -
audio sync trouble on dvd to avi
By zookeeper525 in forum DVD RippingReplies: 5Last Post: 2nd Sep 2007, 10:23
