nothing works audio and video arenīt syncronized any more
where s the mistake
Well your first mistake is not giving any information regarding your problem. I don't even know if your making a vcd or a svcd, and that makes a big difference.
The most generic advice I can give you is to use bbmpeg for multiplexing. I am assuming that whatever you are making, you encoded it in TMPGenc. I only assume this because its the most popular encoder... For vcds its not so much an issue but with svcds TMPGenc really doesn't do a good job of multiplexing. It doesnt allign sequence headers nor add SVCD svcan offsets, which are both very important in maintain sync. Try demuxing your mpg in TMPGenc and the remultiplexing in bbmpeg and see if that solves your problem.
If not please give a little more info such as what your making, what software your using, the parameters of your source, and the parameters of your output file. -
I made a few svcd dics and when I played them on any software dvd player they worked great but now I bought a Hitachi 505 E and the audio/video sync wonīt work
You still haven't given any information for anyone to work with. Its not enough to just say that you have a problem, you have to tell us WHAT your doing. Again, what software are you using, what are the parameters of your source and the settings you used to encode with? Have you tried multiplexing in bbmpeg like I suggested?
best software to sync audio and video
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 10th Apr 2011, 00:28 -
Standalone DVD recorder - is there and easier way to ensure audio sync?
By dphirschler in forum Video ConversionReplies: 20Last Post: 30th Dec 2009, 02:57 -
Problem creating a dvd that works on standalone players from .avi xvid file
By brycej817 in forum Authoring (DVD)Replies: 4Last Post: 17th Apr 2008, 17:50 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13 -
looking for software that will analyse lip movement to sync audio/video
By jimdagys in forum Video ConversionReplies: 3Last Post: 8th Jun 2007, 08:05
