I have a new P4, Sony Vaio muiltimedia set up with 511 MB RAM, 80GB HD. Fast PC. But it gets very s-l-o-w to process operations after a long encoding session. I run chkdisk and defrag, which helps, but find I am doing it more and more. Any ideas on what's happening here? Thanks.
Probably a memory leak or orphan process caused by one of the programs used, this is fairly common. Do a reboot after an encode, if this brings back the speed its a program bug, not much you can do about it. check Task Manager for any processes still running, but its probably memory.
How long is long ?. I have been encoding with TMPGEnc all day today, I am also downloading from Kazza at the same time, and typing this message, checking email every 15 minuets. Playing sections of movies/songs
Do you have case fan's ?, and do you have an Intel motherboard, which comes with "Active Monitor" which monitors the CPU temperatures, as well as the FAN, and the RPM of the case fans.
It could be memory leek, but it could also be the temperature of your CPU, shutting the speed down for a rest
P4, 1.6, Intel motherboard. -
Nothing like a good restart after an encoding session, or after any strenuous computer activity for that matter.
Visit my webpage at:
http://leech.at/e-z-e -
Hate to do this, but think I might have to reformat and carefully, selectively reinstall some apps. Guess it's possible that I loaded up too many different DVD burning and encoding programs in the process of learning all of this stuff. Maybe it's affecting the PC.
I dont see how, I have a huge amount installed, but before you do anything, have you checked for a virus ?. Have you checked for spy wear ?
To start again, you don't need to format, why does everybody do that ?, there is only 2 folders to get rid of, once they have gone you can do a fresh install. Any other folders outside of these 2 can be deleted (If its a program install) or left alone if its you backup.
C:\Windows and C:\Program Files
Windows 95/98
1, restart in MSDOS
2, type "smartdrv" (Enter)
3, type deltree windows
4, type deltree progra~1
Now restart computer, and boot from startup floppy.
c:\>smartdrv
c:\>deltree windows
c:\>deltree progra~1
Press enter after each of the above 3 commands.
If bad command or file name, change to c:\windows> before you use the command. Smartdrv is a hard disk cache. progra~1 is c:\Program Files but its 8 bit name is progra~1
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
DVD shrink fails to rip home recorded dvd in multiple sessions
By sybariten in forum Authoring (DVD)Replies: 9Last Post: 21st Aug 2007, 22:42 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31 -
DVD Multi-sessions - How to Do?
By markannab in forum Authoring (DVD)Replies: 20Last Post: 19th Jul 2007, 21:03
