  1. Hello to all.
    I'm new at this "game" so i have this problem :
    On the Computer a movie ( AVI ) is OK - BUT when i'm burning it ( to see at TV ) it's been turn upside down ???
    I'm using NERO 5.5?? WHY - What can i do about it ???
  2. Flip your disc over when you put it in your DVD player.
    Seriously, this seems unreal.
    Nero will not invert the image, it has to be in your conversion process, or within the original file.
    Need more info. What conversion tool are you using. What settings, and is it just with one file or with all of them?
  3. i had this b4....well first thing is, did u encode it? or did u jsut use nero to burn it? theres a feature that u should have checked....maybe in nero make sure CD i application and standard complaint CD....the standard compliant CD doesnt have to be checked if u are doing xvcd. hope this helps
