  1. I am going to buy a VCR in the next few days. I would like to pick it up from Best Buy or Circuit City, but I might buy online. I want a S-VHS recorder, but that isn't possible in my sub $70 price range. I don't want anything used. Any suggestions please. What brands are the best? What features should I look for? My main use is outputting DV footage to tape w/ Pinnacle Studio 7 via composite video and RCA audio. I don't need Macrovision disabled, just a VCR built for precise recording.
    -Chris
    Science is everything we understand well enough to explain to a computer. Art is everything else. - David Knuth
  2. um... wouldn't it be better to convert your finished DV files to VCD/SVCD? after all, that is what this site's all about
    -Mark
    Swim with me
    And we'll escape
    All the trouble
    Of the present age
    Finally free
  3. Well, my DVD palyer doesn't play SVCDs And I actually get the same quality on a VHS then a VCD. Plus, no converting times! Also, I if I wanted to distribute a video product, VHS is user-friendly and is wider used in the general audience.
    Chris
  4. I think the point is that you are off topic.
    Canada
    Hi,
    People around here are spending more than the original cost on 10-year-old "editing" decks to repair/rebuild them. Why? Because none of the newer ones have anywhere near the same mechanical and electronic quality.
    Allan
  6. WTF are you talking about?!?! This post was about VCR recommendations, but I just bought one so thanks anyway. Allan 55, can you please elaborate? How does your post have to do anything with my topic? Why do you metion editing decks? I was under the immpression that most people here use Software based editing programs to edit video. (thats what i use)
    -Chris
    Canada
    Hi,
    The point is that IMHO there aren't any good quality VHS decks anymore (Editing decks are from days before computers took over editing).
    For example, I can play 20+ year-old rental VHS tapes with good results on my old editing deck (an expensive Sony) and the same tape is pure garbage on a JVC and a Panasonic (both current models).
    It isn't that anybody wants to edit tape-to-tape anymore; its that these decks have high quality mechanisms and electronics which give much better results during playback.
    Allan
