OK, Maybe the impossible but after investing in HPs DVD 100i and paying the extra $99 to get the upgrade to the 200i, I still cant get my productions using Memorex DVD+RWs to play in my Samsung DVD M301 Player!!! Works great in my PC though!
I've tried...
- the software that came with the burner.
- NERO
- Ulead DVD Movie Factory
Is the player not compatible with these disks (DVD+RW) or am I doing something wrong?
Any and All responses are GREATLY Appreciated!
Thanks!
Results 1 to 9 of 9
Yep!
Thanks, I was looking there before my post and noticed only one response related to DVD+R/RW. And the answer was no!
All I'm asking is if this player is some sort of pre-dvd writable generation player that wont play any dvd writable media and if anyone has had any experience with trying to make it work or getting it to work.
Thanks!
Ok!?!
Something dissapointing, at least for me!
I called Samsung tec support (1-800-samsung) and was told this model (dvd-m301) will not play dvd writeable/rewriteable media of any kind!
Kinda dissapointing since I made my decision to buy this unit (dvd200i) based on HPs compatibility list at...
http://www.hp.com/cposupport/information_storage/support_doc/lpg41401.html
To quote them:
"For DVD players, compatible means DVD+RW / DVD+R discs are recognized by the player and successfully played back."
I think they mean the disk will fit in the dvd tray and you can open and close the tray.
Im dissapointed!
Boy what an expensive mistake!!!
Nothing else to do now except fork over another $150 for another player!
Thanks HP for nothing! @#$%
Please take this unit off of your compatibility list! -
Hi,
The DVD Player does read DVD+RW (and most certainly will read DVD+R as well). You need to run the bitset utility for it to work though. Here is the link....
http://www.dvdplusrw.org/resources/bitsettings.html#pc
Hope this helps.
8) -
Go here too...
http://www.dvdplusrw.org/resources/compatibilitylist_dvdvideo.html
If it can read DVD+RW it will most definetely and likely read DVD+R.
To: jowel13
Thanks for the reply.
I've been this route too! I've tried this utility from the installation CD and downloading. I've set the drive & disk from mode 1 & 2 and back and have had no luck.
Could you email me and let me know what the correct settings are for this utility?
Thanks! -
Also,
you can post in www.dvdplusrw.org, a lot of users had similar problems and they fixed it in no time.
SOS! I have output file from convert by mencoder but i don't know conmand
By zerround in forum Video ConversionReplies: 0Last Post: 24th Feb 2012, 02:38 -
SOS Win7 Update hangfire- #8 never completes
By ahhaa in forum ComputerReplies: 3Last Post: 17th Feb 2012, 01:48 -
SOS- Registry Help Needed: Stop Repeating Windows Installer (XP)
By ahhaa in forum ComputerReplies: 6Last Post: 20th Nov 2011, 07:41 -
SOS: how to capture flv,
By dainova in forum Video Streaming DownloadingReplies: 6Last Post: 19th Oct 2011, 12:26
