If you can help !!
I have tried the following
copied 3 svcd's to hdd
put them in to dvd2avi
got the two files a .dv2 and an .wav file
opend tmpeg loaded both files in correct order
gone in to test the video about five mins from the end and the lips sync is a good 10sec out
is there a setting that Im not doing as this seem s to only happen
when comming of svcds and ripped dvds
I have the hauppage usb capture card I can record of the satellite
using the same methord as a bove with out the lips sync prob
got as many codecs as pos
N E thoughts would be much appriciated
KAce
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Best way/tools to sync audio to movement of lips?
By J-E-T-S in forum AudioReplies: 18Last Post: 8th Mar 2012, 17:06 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 10:31 -
Sync Problem
By anirban in forum Newbie / General discussionsReplies: 8Last Post: 1st May 2008, 12:15 -
a/v out of the sync problem...
By drstupid in forum Newbie / General discussionsReplies: 6Last Post: 12th Jan 2008, 01:27
