i have avi. film using virtual dub to rip audio but when i load avi into virtual dub it says improper vbr audio encoding in source avi will rewrite audio header with cbr valuesand may produce 17242ms of skew ,if not exceptable decompress entire audio to a wav file and recompress with a constant bitrate encoder(bitrate 138.3 15.7kbps)
i rip audio with virtual dub decompress it etc then use tmpeg to make my vcd then audio sync goes,i dont know how to do this recompress with a constant bitrate of 138.3 15.7kbps plz help have wasted alot of blank discs
What its telling you is, if you wanted to make a new AVI, then you would need to recompress with a constant bitrate, but since you are not interested in this, you only need to save the WAV file uncompressed, then it will be just fine for use in TMPGEnc.
If you save out the WAV without changing anything, it will be no use... So....
In Vdub, select Audio > Full processing mode
Now select Audio > conversion
Change the sample rate to 44.100Hz, leave the rest alone.
Now click File > Save WAV
The will now save out a large uncompressed WAV file, ready for TMPGEnc.
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
DirectShowSource prob for AVI(DV) to MP4
By sekaiji in forum Video ConversionReplies: 3Last Post: 29th Jun 2007, 19:43 -
avi to mp4 with MeGui prob...
By sekaiji in forum Video ConversionReplies: 2Last Post: 29th Jun 2007, 17:48 -
AVI audio prob or video
By SilverDales in forum Video ConversionReplies: 8Last Post: 25th Jun 2007, 16:50 -
audio sync prob AFTER burning !
By bluraid in forum Newbie / General discussionsReplies: 5Last Post: 21st Jun 2007, 06:28
