Hey guys new to capturing need a little help,
i have a aver tv card and i use the aver software which came with the card.
it allows me to record straight onto my hard drive in either mpeg 1 or 2 format.
mpeg 2, 352 x 288
mpeg 1, 352 x 88.
i have tried to capture a video i have with rubbish results,
when i capture it to the hard drive it looks great, but when i tranfer it to
vcd it looks and sounds crap.
i have also tried the same in mpeg 2 with the same kind of results.
i have also rigged the pc upto the digital tv, and again it looks great on the pc but when i copy it to vcd it looks preaty bad.
i have also tried to take the mpeg i have captured and re-encode it
with tmpge it looks alittle better but not much,
i have also tried to use virtualdub, but it does not reconise the capture card.
what im trying to find out is what im doing wrong.
its it a crap capture card, am i using the wrong software, should i stop capturing straight to mpeg format? i need all the advice i can get here,
my pc has a 20 gig harddrive, and is a 500mhz.
i dont know what else i can tell you,
please help
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Capturing from television? Is this possible?
By Kite in forum Capturing and VCRReplies: 6Last Post: 26th Sep 2009, 07:34 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
