After using pulldown.exe my audio will not sync up with my video when I multiplex. Any help is greatly appreciated.
You need to give LOTS more info.
What is your source dvd, divx, other???
What are you making a vcd or a svcd???
How are you processing your audio and video?
There are literally dozens of factors that could be causing your sync problems and its impossible to narrow it down without at least some info to work with. -
Hmmm, for some reason I can't edit my post... I had a momentary lapse of reason earlier, obviously you are making a svcd if your using pulldown.exe.
Its a divx file. 23.976 fps
I encode with with cce
the I use pulldown.exe
I convert the audio with tmpgenc
I have multiplexed with bbmpeg, tmpgenc, and lsx encoder.
Audio is a few seconds behind the video
2:4 Pulldown
By supervehicle in forum Video ConversionReplies: 23Last Post: 3rd May 2011, 17:53 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 12:34 -
3:2 Pulldown and Interpolation
By PuzZLeR in forum Video ConversionReplies: 1Last Post: 28th Oct 2007, 12:49 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 07:38 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 04:25
