Hello,
I have a Celeron 1.1Ghz with a Tnt2 (32mb with tv-out), and i would like to watch movies on my tv from my pc. My question: how can i make a connection between my pc and tv. My tv has an s-video input.
Should I buy a cable to make a connection between my VGA-port and the s-video input? I really don't see how I can do it because the s-video input is round and the VGAport is rectangular.
Can someone please tell me in several steps how i should make such connection?
Thanks.
my email: witte125@hotmail.com[/b]
You Vid card has two outputs, one for VGA -> monitor, one S-Video-> S-Video in.
You need a standard S-Video cable to connect the TV to the PC with said S-Vid cable. Then you will need all kinds of patience and persistance because it can be a real pain in the arse to make it work and after you get it mostly working you'll wonder why you bothered but good luck anyway. -
Just a note : SVHS cable caries no audio so you will have to trail another cable to your tv unless you use your pc speakers. If you are more specific about the type of connections on your card we may be able to help further. Good Luck
8)
Connection help please
By Malissa in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Dec 2011, 09:10 -
t.v. connection problem
By brenda1906 in forum Newbie / General discussionsReplies: 10Last Post: 27th Mar 2010, 07:18 -
PC to TV Connection help
By mohit in forum Media Center PC / MediaCentersReplies: 5Last Post: 22nd Sep 2008, 15:15 -
By mohit in forum Video Streaming DownloadingReplies: 1Last Post: 21st Sep 2008, 10:03 -
DV 1394 connection
By Gravez in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 9th Jun 2008, 11:57
