I converted Divx to SVCD using TMPGEnc and KingViper's SVCD Template.mcf. The quality is great (considering 130 min SVCD is on one CD), but after I search (fast forward, rewind, etc) the picture becomes unstable...blocks and strips of the picture are missing. Anyone know why this is, or how it can be corrected?
Enc process:
Stripped the audio via VirtualDub
Loaded KingViper's SVCD Template in TMPGEnc using orig Divx and WAV
Changed Motion search Precision to High Quality
Changed Framerate from from 25 to 23.976
Everything else I left alone
*I wouldn't think this would matter, but I also multiplexed the MPEG2 and rewrote the headers to MPEG1 so the SVCD would play on my Sony.
**The BNR feature on my player didnt get rid of the problem either.
***The only way to get rid of the problem is to eject the disc and start from the beginning.
FYI I figured out a workaround. After encoding to MPEG2, in TMPEGEnc do a Simple Demux, then use bbMPEG to Mux as SVCD. If you need to, then you can MUX in TMPEGEnc to rewrite the headers from VCD to SVCD to trick you DVD player into playing the SVCD. I'm not quite sure about the specifics of the fix, but my understanding is that bbMPEG calculates the correct scan offsets when muliplexing. I'm assuming TMPEGEnc doesn't do this correctly, or at all. If anyone more knowledgable knows whats going on, please enlighten me.
Here's a link which clued me in:
http://www.ghorne.pwp.blueyonder.co.uk/vidtest/bbmpeg.htm
Fast forwarding and rewinding a tape before capture?
By justin81 in forum RestorationReplies: 4Last Post: 14th May 2010, 16:41 -
Video freezing when fast-forwarding.
By xcodyj in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2010, 03:45 -
Viewing during VCR fast forwarding/rewinding
By spinmonk in forum Capturing and VCRReplies: 12Last Post: 30th Aug 2009, 18:30 -
ogm's fast forwarding
By CommanderZero in forum Newbie / General discussionsReplies: 2Last Post: 21st Oct 2007, 23:23 -
fast forwarding flvs with vlc?
By majax79 in forum Software PlayingReplies: 2Last Post: 20th Sep 2007, 13:54
