Hello.
I have an ASUS 7700 Deluxe card which I think works
flawlessly for my video capturing needs. However I
am having one problem.
When I capture in PAL everything looks and works
more or less EXACTLY as I expect it to. However I
also have A LOT of NTSC tapes lying around that I
was planning to capture using the ASUS 7700 deluxe
card...
The VCR I have (A Panasonic HD-660) outputs a PAL60
quasi PAL signal (60 Hz NTSC with PAL 4.43 color
carrier).
The ASUS should support this video mode as it has
an option reading "NTSC 4.43PAL" in its source
settings. So I set it to this option for video
capturing (also 30 frames per second etc.) and
it works absolutely great -- except NO COLOR.
Since setting it to NTSC 4.43 it SHOULD pick
up the color too if everything works logically.
I am using composite signal to capture. Does
anyone here know how to get around this problem.
Why would ASUS put an option in there specific
to NTSC 4.43 (another way to call PAL60) and
then have it NOT WORK. I wrote them about it
and hasn't heard ANYTHING from them - but
according to this forum it is nothing to be
surprised over...
PLEASE HELP ME WITH THIS ONE. Should I use a
different video transfer mode for keeping the
colors or what? I don't understand what it is
that I am doing wrong here... It is really
quite confusing...
//doskungen
Results 1 to 1 of 1
Catpuring old NTSC tapes in Europe (b\w - color problem)
By Heartworm in forum Capturing and VCRReplies: 6Last Post: 13th May 2010, 21:25 -
Capturing Pal60 With Easycap DC60
By e0turnerl in forum Capturing and VCRReplies: 4Last Post: 21st Mar 2009, 12:07 -
Capture problems, PAL60 option
By CoronaStar in forum Capturing and VCRReplies: 1Last Post: 11th Oct 2008, 08:38 -
Need a CC with PAL60 capability for the UK
By usernameinvalid in forum Capturing and VCRReplies: 21Last Post: 10th Oct 2008, 19:15 -
PAL to NTSC Color Problem
By Drakul in forum Video ConversionReplies: 33Last Post: 29th Jul 2008, 02:58
