I cannot find any software that will encode my avi with audio compressed as mpeg4 to SVCD. They will encode the video but with no audio. says it is unsupported. how do you convert the audio so it is supported. Any help is greatly appreciated.
Just extract the audio as a WAV using Virtualdub then encode using resulting WAV as audio input.
"Today is only yesterdays tomorrow" -
I tried using virtual dub but it says it does not support the Mpeg4 compression. So what else can you use.
I have tried several different encoders, Tmpg, Tmpg plus, Avi2vcd, dvd2svcd, instantcd/dvd, honstech Mpeg encoder. but none will recognize the audio, it will play in all media players with sound but when i encode to vcd or svcd there is no audio.
I think that VDub 1.3d or higher will not use the MPEG4 codec anymore.
Good luck!
reman -
Install the Mpeg 4 Codec.... There is more than 1 you know....Originally Posted by vvolf119
Right click AVI select properties, see which its using... Whoosh rush to shop and get missing codec
try "Nimo Codec pack" its on special -
Who says that ?Originally Posted by reman
It "Might" not support ASF
Microsoft locked the driver in the final 4.00.0.3845 build so that it would only work with Windows Media Encoder. DivX 3 is actually a copy of this driver with the lock hacked out, and the format tags changed to be distinct from the original. The most popular version of DivX, 3.11a, is a pair of drivers that derive from Microsoft's 4.1.00.3917 and 4.1.00.3920 builds. The "unhacked" version of DivX 3 is the Microsoft driver
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 15:24 -
convert compressed avi files to mpeg without increase in file size?
By jasoothai in forum Authoring (VCD/SVCD)Replies: 7Last Post: 2nd Nov 2011, 05:29 -
M4V to AVI in VD, when compressed with Xvid, saves with audio out of sync
By kiki hayes in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2011, 09:45 -
I want to conver a file to FLV format. with audio aac and video as mpeg4/h2
By krishsamy in forum Video ConversionReplies: 1Last Post: 11th Nov 2009, 02:45 -
[SOLVED] WMV to MPEG4/AVI/anything else has increasing audio desynch.
By Eilonwy05 in forum Video ConversionReplies: 13Last Post: 15th Jun 2008, 14:01
