I downloaded movies to my hard drive. Use TMPENC to convert to Mpeg. Now I'm using Nero to convert from Mpeg to VCD so I can see the movies on my DVD. Using the following instruction http://www.vcdhelp.com/nero.htm
I get this error msg " THERE IS NOT ENOUGH SPACE TO BURN THIS COMPILATION ONTO MEDIUM. PLESAE INSERT ANOTHER MEDIUM THAT PROVIDES MORE SPACE"
I have a PIONEER DVD-RW DVR-104. Using Memorex CD-r 700mb/80Minute disk.
Trying to copy the movie (smr)spiderman-ts (1of3), (2of3), and (3of3) each are under 50 min long and about 192,639 KB. Please help!!
Originally Posted by JtQuest
Are you sure aboute the size of the files?? -
I think Nero does not recongize my DVD PIONEER DVD-RW DVR-104.
When I click on "choose a recorder" it gave me a option of "Image Recorder" or my "DVD-RW". I click on my DVD and another window come up and said "Sorry, this Nero version can only be used with the recorder it has been bundle with. To receive a full verison of NERO, please contact sales@nero.com"
What I can Do to fix this so I can burn?? -
Use TMPGEnc to encode to vcd,Neros' encoder stinks.Also you should use the latest version of Nero(5.5.8.2).
Moviegeek, I understand that TMPGENU convert to VCD.
What software do I use to copy the VCD that's on my hard drive to copy to a disk?
And I did dowload the version of NERO (5.5.8.2) -
JT when you downloaded Nero, did you upgrade or clean install and was serial number genral or specific ( bundled ) as there are no Pioneer OEM numbers that I know of yet Nero works fine with the A03 in general serial mode.
Also are you burning the bin/cue files of Spiderman in Nero, if so then go to FILE--- BURN IMAGE... then load up cue sheets and burn. Be aware that your Spiderman copy may be PAL SVCD, and may not playback properly, I had to convert to normal NTSC SVCD for playback.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
