  1. When I choose "Video Format" I see that the frame size is set to 320x240. The only higher options are 352x240, 640x240, and 720x240. How come no 640x480 or 720x480? What size should I use if I want to capture the highest quality possible and then create a DVD? I thought I would want do to like 640x480 or 720x480 but they are not available. Thanks.
  2. What capture card are you using? It sounds like a capture card/drvier limitation. I can capture 720 x 480...
