I have a TV Tuner card and currently use the program CyberLink PowerVCR II ver3.0 [ http://www.gocyberlink.com/english/products/product_main.jsp?ProdId=20 ] to recorded off air programs.
This software allows for different quality setting of the recorded file.
I have been using the highest setting which was MPEG2 640 X 480 which looks great on my computer.
But this past week their was a local news program that I recorded and wanted to burn to S/VCD and I can not seem to find the correct conversion program to change the file format to the S/VCD format.
I use NERO to burn my standard audo/data CD's and purchased the MPEG2 encoder from Ahead software and when ever I try using it to convert the file the audio track seems to loose about one second per-minute... so that after about ten minutes of play the audio is out of sync by ten seconds.
I have also tried :
TMPGEnc, VurtualDub, and VCDEasy
And either they could not read the input file and or the output once converted was really REALLY bad!
Can you suggest an other program which would convert the file to the correct burning file format that NERO will burn?
--David
Results 1 to 1 of 1
DVD+R won't play, have I bought the wrong format? - New post/problem 15/12
By yultie in forum MediaReplies: 20Last Post: 17th Dec 2010, 13:59 -
Wrong Source Format 16:9 vs 4:3
By aluri in forum ffmpegX general discussionReplies: 4Last Post: 23rd Apr 2010, 07:21 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
What is wrong with this format for youtube?
By ingeborgdot in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Jan 2010, 12:54 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15
