Hello,
I have followed the all in one guide to convert DIVX to VCD.
The conversion id going fine but, on the final VCD file, the video is way much darker than the original file, at a point that certain scenes (during the night for ex) are just a big black screen.
WHat should I do please ?
Thank you
Beuz
You need to see if it looks ok on your TV, if you change the brightness during conversion, it can lower the quality, and might look too bright on your TV.
Yeah ive had that same problem with some movies i was trying to burn to VCD.
I once was able to get it to work when i converted it useing VirtualDub. try that. -
It is easy to change the brightness in TMPGEnc, just hit the settings button, then the advanced TAB. There you will see "Simple colour correction" You can adjust the settings while viewing the dark frames, don't add too much.
Surely increasing the brightness on the TV will be better ?, if the movie is so dark, it cannot be improved, if there is nothing there to improve ! -
You would increase the gammer, if the gammer needed increasing. You would increase the brightness if the brightness needed increasing.
I'm sure with all those sliders, your going to move them all
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
Problem with TMPGEnc DVD Author 3 with DIVX Authoring
By LadyTaz in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2008, 20:36 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
I have a problem with TMPGEnc 3.0 with DivX...
By blasedeviant in forum Video ConversionReplies: 2Last Post: 1st Feb 2008, 22:10 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07
