Downloaded spiderman ex quality but when I try to split it to put on 2 cd's it only gets about 5mins into film and sticks at that point same place every time. If i then try to merge/cut after that point i get invalid mpeg file message. i need an idiots guide to this spent hous trawling thru vcd help pages and getting no further forward any help gratefully appreiciated
Well at leased when they are AVI, there is a lot more things you can do, However Mpeg's were not designed to be edited, so the only thing you could do is load into Vdub and delete the bad frames.
This means you need to save out a AVI...
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 22:55 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 07:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 10:13
