Last night I saw screens of the Lord Of The Rings (1st film) encoded to SVCD and the quality was outstanding. Could someone tell me how to get the same quality + wich program I should use for it. I don't care about the amount of cds to use
to rip a dvd you need "dvd decrypter", flaskmpeg and the divx codec. this will give you an avi movie in divx format. you can then use virtualdub and tmpgenc to create a vcd (2 discs generally) that will play in most dvd players
If you want the highest possible quality SVCD, Divx should not be involved at all. Rip it using Smartripper or DVD Decryptor, and frameserve from the VOBs to CCE.
how do you bypass the divx stage in making a svcd and will it work for vcd's as well?
For SVCD use DVD2SVCD and TMPGEnc. Usually 2 -3 cd with supurb results. It is very easy. It takes 6 -10 hrs on my Pentium 4 2.2 It is almost all automatic while you sleep
Where the heart is is where the soul goes, when it is all over.
Encoding question??? Need advice please
By Tony Cymmerman in forum Newbie / General discussionsReplies: 0Last Post: 12th Jan 2012, 18:55 -
Encoding Question
By ne0natas in forum Video ConversionReplies: 1Last Post: 7th Feb 2011, 21:46 -
I've resolved so much, but still have an encoding question...
By takearushfan in forum AudioReplies: 10Last Post: 9th Jun 2010, 10:25 -
re-encoding question
By Mauserman in forum ffmpegX general discussionReplies: 2Last Post: 17th Feb 2009, 16:42 -
audio encoding question
By spittle in forum AudioReplies: 1Last Post: 26th Jun 2007, 18:47
