Which of the following capture cards is the best, and for what reasons?
WinTV
ATI TV Wonder
Dazzle
any other brand
What brand would your recommend?
Choose a device that is either 1394 Firewire(good for DV) or pci(good for vhs,HI-8),usb(good for nothing) is the worst video quality.
Well I can tell you that most of them have really BAD customer support!
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
Dazzle doesn't. They have really good support.Originally Posted by The village idiot
Pinnacle is good, but if it has a firewire port check it will work with your camera. At work we bought a DV500+ it doesnt work with our DVCPRO camera (profesional quality). Pinnacle wasn't very helpful but otherwise the card is great. It's also worth looking at the software bundled with the card.
Later BRETT
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 12:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 10:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 10:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
