I have blade 2 on vcd but only the second disk will play on my computer the first disk says its unsupported when i try to play it.
Any help would be greatly appreciated!
I cant i did not download it and dont have the avi file to remake it from.
I definately dont want to download something i already have as well. -
Ok, try copying the large DAT file from the VCD onto your hard drive, then you can use that to make a new VCD
Extract the dat file with vcdgear (www.vcdgear.com) to mpegfile and try to
re-encode the file to a vcd compatible dat.file
trench -
if the vcd wont play on his computer then i doubt using the dat/mpg file from the vcd will work... your probably going to have to download it again
try download it agin. All the coverting turn the to a file to a POS or just pay some 2 bucks and I am sure they will burn you a copy.Originally Posted by mitchellwwf
We will never know, looks like he has gone....
Just because the disk is unsupported, does not mean its a coaster, it might just play on another DVD player.
The Dat file wont need to be converted, Nero, easy CD, Video pack 5 all will use them as they are. and Media player will play them if you rename them to mpg.
I don't get why Blade Runner is special - ok movie but a classic?
By yoda313 in forum Off topicReplies: 24Last Post: 28th Feb 2011, 17:36 -
Laserdisc: Blade Runner
By vhelp in forum Off topicReplies: 11Last Post: 2nd Aug 2008, 00:19 -
Blade Runner Briefcase Dangerous Days (Disc 2) menu problems after shrink
By jrshull in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 13:49 -
Blade House of Chthon
By raymond_barnes in forum DVD RippingReplies: 1Last Post: 19th Sep 2007, 23:50 -
blade test
By raymond_barnes in forum TestReplies: 0Last Post: 19th Sep 2007, 22:54
