I have used the TMPGenc to cut a 2 hr VCD movie into two files, it did its thing ( took about 12 min for each file ) but then when I went to record it using Nero 5.5 Nero tells me that the file is not a compliant VCD file & it is asking to reencode it. Before the cut it was not asking me that question.
Any idea what happens to that file?
"Computers are stupid, but they are capable of being stupid one million times per second"
You must make sure you select "MPEG-1 VideoCD" from the Type list in the Merge & Cut tab of MPEG Tools window.
PhArAoHWinners never quit, quitters never win. Those who never win and never quit are idiots. -
that's is easy turn off the vcd complaint or burn it like svcd and do the same turn off svcd complaint ,but it problably will not play in your dvd becuase nero is telling you that is not complaint
Go ahead & burn a non-compliant vcd (some dvd players will play them anyway) that way you can fiddle with your bitrates to get a better quality video file (higher bitrates mean less playing time per disc however)
(check & see if your player is listed here - then you'l know what options you have for vcd's)
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 11:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 14:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 15:58 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 17:56
