My VCD’s don’t play well on my Computer and sometimes don’t play at all on DVD Player. I have created them by capturing Video, the converting it to MGP with TMPGEnc with the Video CD (NTSC) setting loaded. When I go to burn the VCD with Easy CD Creator 4.02 it tells me that the System Clock Speed us unacceptable but I can Burn the VCD anyway. Do I have a setting wrong in TMPGEnc or is that normal? Would this be causing my VCD’s not to play?
i would use a program like nero to burn them...its pretty easy from there
Even if you have nero, you will still need Xing MPEG player cuz most vcds wont work well in windows media player. If you need the full version, email me.
ShiZZZoN~ Your Pirater for less
problem with Subtitle Creator
By heof in forum SubtitleReplies: 12Last Post: 17th Jul 2010, 02:14 -
Problem with subtitle creator 2.2
By ashkan_vpm2 in forum SubtitleReplies: 0Last Post: 1st May 2010, 18:43 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
WMV to DVD and problem installing Easy Media Creator 10
By jhayes in forum Video ConversionReplies: 3Last Post: 10th Mar 2008, 15:26 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 16:27
