  1. When you go to the pause option and it shows 'seconds' or 'infinite' what does infinite mean? (sorry if im spelling it wrong) I usually just put 0 seconds but the cd still stops before the next track starts.
    Victoria, Australia
    effectivly the same thing, it will pause forever at the end of the track
    Later BRETT
  3. So there's no way to make it all run smooth ? I would like my concert cds to run without those annoying pause
  4. Can't do it with Nero, but you can do this with VCDEasy by using chapter entrypoints. The key is to use a single long source MPEG (not multiple MPEG files) and place chapter entrypoints within it with VCDEasy. Works great. For more info on this see
    http://forum.vcdhelp.com/viewtopic.php?t=77044&highlight=
    Hope this helps,
    vcddude
