I've seen some really good quality SVCDs Musicvideos out there the internet and prepare to match them.
But I come across a really annoying problem which i hate. Then i capture with codecs like HuffyUV and PicVideo, they do not drop frames, but when i come to encode them in TMPGenc, the interlace lines are there. Should they be there?? I capture in 480 x 576 and still come up, also capturing at other sizes still make them come up.
If the interlace lines are suppose to be there, what can i do?? I've tried putting up with this using the Deinterlace filter in TMPGenc and it looks not too bad, but when finished encoding, i can see alot of ghosty movement which I don't want. Is there neway of avoiding the interlace lines when caputuring?? Or do I have to manually remove them in a special way to maximise quality??
I'm capturing using a ATI AIW 128 Pro and like in UK (PAL)
If you've tried both field A and field B first in your encoder with no joy, try ticking the "swap fields on decompression because of buggered capture driver box" in your huffyuv codec setup. Field problems can be a common occurence because of shite drivers.
Cheers,
Bolix
Re-compressing many times with lossless codec in Vdub introduces colorbleed
By Mephesto in forum Newbie / General discussionsReplies: 21Last Post: 19th Feb 2012, 06:39 -
VDub and interlacing
By koberulz in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2012, 10:05 -
Interlacing problem?
By killerteengohan in forum DVD RippingReplies: 16Last Post: 18th Aug 2011, 06:24 -
De-interlacing problem?
By fredo2010 in forum Video ConversionReplies: 17Last Post: 27th Oct 2010, 15:48 -
Good Video Explaining Interlacing and De-Interlacing
By Soopafresh in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2008, 19:50
