Hi
I captured a video using my GeForce3 Ti200 tv card and the file format is
Mpeg-2
Video 720x576 bit rate: 6400kbit/s
Audio bit rate: 224kbit/s
The settings for the card were to encode in DVD (PAL). The file was also stored with the .mpg extension.
The problem is I cannot find a tool to convert this to SVCD. Is there anything that can hanndle this or is there any tool that can do it in stages i.e. to VOB then maybe with DVD2SVCD etc.
See if you can load it into DVD2AVI. If you can, you should be in business.
Alternatively, VirtualDub is pretty neat at capturing Video, and there are some guides here on the site, I believe.
Conversion Problem
By Myrdivar in forum Video ConversionReplies: 3Last Post: 2nd Jun 2011, 04:44 -
Problem with conversion to DV
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 08:54 -
conversion problem
By thomeski in forum Authoring (DVD)Replies: 2Last Post: 25th Apr 2010, 20:45 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 05:51 -
video conversion problem
By eagle1 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jun 2008, 21:25
