Hi group.i'm new here but not that new to converting avi's to vcd.I have a problem that is really bothering me and i hope i can get some sort of answer here please.The problem is is that i downloaded the film From HEll in avi format,but when i try to play the film with mediaplayer there is no sound.I also tried to convert the avi to mpeg using tmpgenc but an error appears saying the the file is unsuported.It will convert the video file but not the audio.Is this a terminal problem with the whole file or is there a way of trying to fix it?I have tried virtualdub but i can't get that to work properly either.Please help me.Many thanks,Ryan.
Install the "Nimo Codec Pack" should fix the problem.
Sounds like you have a missing audio codec
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
