Hi. Sorry for the silly question, but it realates to Virtual Dub. Once you've captured,say for example a multisegmented 20min 10Gig file,broken up into 2GB parts to avoid FAT 32 filesize issues.
Afterwards you've had the file & segments load up into the Vdub editor & used all the filters & selected your compression codec & ready to save your edited file.
You still probably have at least a 9-10GB file left,so how do you save what was previously a multisegmented file of 5x2Gig AVI files? If you just choose the option to save as an AVI file,won't you break the file size limit?
How do you save the over 2GB edited file in Vdub?
Thank you for stating the obvious!
Results 1 to 1 of 1
Saving file question
By jyeh74 in forum ComputerReplies: 4Last Post: 14th May 2011, 20:41 -
Stupid question about BD50 to BD25
By timmus in forum Blu-ray RippingReplies: 2Last Post: 11th Sep 2010, 20:26 -
Stupid Divx HD on PC Question
By belfastrab in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2009, 00:18 -
Adding a text logo to a video file without re-saving it to another file?
By coxanhvn in forum EditingReplies: 4Last Post: 19th Dec 2008, 15:03 -
Probably a stupid question, BUT...
By HmNtr in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 7th Dec 2008, 12:22
