I want to covert an audio DVD to a CD Rom to play it in my car
What is the best and fastest way to do this
Well the only way I could think of doing this would be the rip the dvd>convert to a high quality (for good sound if you want it)>and then get VirtualDub and Save the WAV and convert to MP3...
This is basically the only way I could think of doing it. You would also get the movie
SteveDVD does suggest a good way but my way is easier. Simply download this http://www.gbfans.co.uk/digiguide/dvd2divx_ac3dec.zip zip file. extract this to the folder where the vob file is and just drag and drop the vob file over the ac3dec.exe file and then let it do its work, it will span over to the next vob untill it gets to the end of the last vob file.
DVDAuthorgui wave audio support?
By video_magic in forum Authoring (DVD)Replies: 19Last Post: 8th Jul 2010, 16:39 -
audio wave forms in video.
By kingtiger in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2009, 17:36 -
Wave Hammer and Audio Takes
By solarblast in forum AudioReplies: 0Last Post: 24th Nov 2008, 08:09 -
audio levels keep changing, 5.1 ac3-to-wave
By spiritgumm in forum AudioReplies: 0Last Post: 22nd Mar 2008, 09:56 -
Belight settings for correct wave/ac3 volume conversion?
By spiritgumm in forum AudioReplies: 0Last Post: 29th Feb 2008, 12:19
