The captured Video looks fine.(I am using Pinnacle DV500 pro). I have tried all the applicable export options... When I convert to MPEG, still ok. When I use TEMPGEnc the "problem" shows up...... The view looks as tho there are "Rain Drops"being viewed thru a window.
I have changed connecting cables, moved them to isolate thinking maybe the problem is noise related...Replaced the video card, added ram so I have 512 megs. (I never drop frames when capturing) I have also tried a different computer to no avail.
http://www.paypalwarning.com/
Does it rain here?......Yes it does......Frequently
from the Murky Island
ED... 8:17:07 am
8 JUN 2002
ED... 7:40:49 am
8 JUN 2002 -
Your "raindrops" are most likly common compression artifacts. What format are you using? VCD? Do not compare DV video with VCD, you will loose 3/4 of the video quality...
Because I haven't found a way to go directly to mpeg2 on exporting from Pinnacle DV500 Pro, I first select mpeg, then TMPGEnc and running it is where I first see the *RainDrops*.....
ED... 11:14:26 am
8 JUN 2002http://www.paypalwarning.com/
ED... 7:40:49 am
8 JUN 2002
Appropriate pixels?
By bsuska in forum Authoring (Blu-ray)Replies: 52Last Post: 20th Oct 2010, 09:33 -
how do I convert a video that shows square pixels to no pixels?
By sxpredman in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2010, 03:56 -
pixels with vegas 8.0b and not 6.0d
By Sepu in forum EditingReplies: 0Last Post: 7th Jan 2010, 06:54 -
Another question: Converting square pixels into round pixels.
By Earthling2000 in forum Newbie / General discussionsReplies: 13Last Post: 23rd Nov 2009, 11:20 -
Flickering / Fluttering / Frame dropping...is this copy protection??
By mik534 in forum DVD RippingReplies: 9Last Post: 2nd Oct 2009, 07:55
