Hi Guys,
At the moment i'm running -----
P3 600mhz on a Gigabyte BX2000 mobo
40gig fujitsu 7200 Master Harddrive
46gig 7200 IBM Deskstar slave Harddrive(its away getting fixed at the minute)
384meg of pc100 sdram
Chaintech Geforce 2 MX 64meg AGP Graphics card with TVout
Soundblaster live 1024 sound card
CRAP pair of speakers
Toshiba DVD rom drive
Plextor 12x10x32 Writer
Motorola Surfboard Cable Modem.
Now that the specs are out of the way, my question is what Video capture card should i buy.
I don't know which would be best for my system.
I'm new to the capturing part of Video to VCD/SVCD but
i'm up to date on converting Divx to VCD/SVCD.
So if any of you good Folks could help, it would be appreciated.
Thanks in advance
<font size=-1>[ This Message was edited by: marvel2020 on 2001-08-03 14:48:22 ]</font>
Just received a dazzle II. It hardware captures in VCD or SVCD format. You have to make your own templates to get great capture. Just copied a few DVD's with DVD quality. Just capture, split and burn. No time consumming processing envolved. Best purchased I made because I also spent money on the Marvel G400 and Hauppague PTV cards. I consider those cards bad because it took 15 plus hours to process one average length movie and the quality wasn't that great.
<font size=-1>[ This Message was edited by: Freddie100 on 2001-08-03 14:13:33 ]</font> -
I just saw a ATI All in Wonder capture card and i think it's great because this integrates a 3D accelerator, CableTV display, video capture, some other stuff... all this in a PCI card. One thing that i don't know is that if this card captures directly to VCD or SVCD format, i don't know.
I have a Pinnacle DC10+ card and it's great too (only Video capture) This captures MJPG 8motion jpg8 then i have to wait for the conversion from AVI to MPG to get a VCD!
ATI AIW is great but is more expensive than DC10+ -
Thanks for replying Guys.
I've been doing a lot searching + reading since i made the post and i've decided that a Pinnacle card would be best for my system.
Thanks again -
I ALSO USE A DAZZLE DVC2,AND VERY IMPRESSED WITH THE QUALITY AND THE EASE OF USE.
Capture Card Unigraf UFG-03. Where is I can buy it?
By Andrey97 in forum ComputerReplies: 3Last Post: 3rd Feb 2011, 12:51 -
I'm having a problem deciding what Capture Card to buy
By Mufc in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2010, 10:10 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Looking to buy a capture card or any other related product.
By jonathan3566 in forum Newbie / General discussionsReplies: 11Last Post: 7th Jul 2007, 02:10 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
