Nort knowing where to post this....
If I record on a machine with an ATI card with YV12 compression, and then convert to SVCD it's a very good pix.
If I record to RAW RGB, 24bit, the playback of the avi file is perfect, but any attempt to convert, leaves me with a color moire problem, (gonna try to explain) as in a fellow wearing a brown coat, instead of the entire coat being brown, the center of the coat is a light brown and as you progress to the outer portion of the coat it gets progressively darker.
The avi is MUCH cleaner and sharper with 24 bit RGB, then YV12, but no matter what I try, converting is, let's say, not a good thing.
Any help would be greatly appreciated.
Using VDub to capture (a Matrox card) and TMPEGenc 2.54 to encode using standard templates.
Making me crazier then I already am, so ...
Results 1 to 1 of 1
YUY2 vs RGB24 vs Y800
By 201flyer in forum Software PlayingReplies: 40Last Post: 28th Apr 2011, 07:11 -
What would be a great room size for great video production?
By williec in forum Newbie / General discussionsReplies: 0Last Post: 3rd Apr 2011, 04:43 -
vga and svga
By thejollypostman in forum Newbie / General discussionsReplies: 1Last Post: 9th Sep 2009, 18:36 -
DVD to DVD: YV12 to RGB to YV12, color problem ???
By cd090580 in forum RestorationReplies: 9Last Post: 24th Oct 2008, 11:16 -
SVGA and VGA?
By warlock110 in forum ComputerReplies: 1Last Post: 11th May 2007, 20:07
