when I connect my pc to tv via tv out on AV 1, everything loads up perfectly, only the picture is black and white. If I connect using AV2 then it loads in colour but only as far as the black XP start up screen, then nothing else happens. Can anyone please help.
Many thanks
Phil![]()
How are you connecting to your tv? maybe SVHS cable to scart converter, Is your AV1 set up for SVHS input? if not it may give you this problem. Check both AV inputs(on mine when I flick between them both the on screen menu says SVHS input) Also can you change the TV out to PAL etc that's If you are using composite. Note SVHS cable gives no audio.
Vegas 9.0 Camera not connected
By solarblast in forum Capturing and VCRReplies: 2Last Post: 26th Mar 2012, 17:25 -
Do I need a new graphics driver for this newly-connected monitor?
By jeanpave in forum ComputerReplies: 6Last Post: 3rd Dec 2011, 04:08 -
wont recognise camera connected
By sarah1 in forum Newbie / General discussionsReplies: 4Last Post: 6th Apr 2010, 06:09 -
Connected PC to LCD TV, colors all Green
By Vangreal in forum Newbie / General discussionsReplies: 1Last Post: 19th Jun 2009, 11:25 -
Do you use a VPN when connected to a free hotspot?
By freebird73717 in forum ComputerReplies: 6Last Post: 14th Aug 2008, 07:38
