How do I play a downloaded vcd from my hard drive? the file is an MPEG but my Windows Media player say it does not support the file type and spits out this error Error ID = 0x80040265, Remedy ID = 0x00000000 Can anyone help?![]()
Adam Mason
you need to get codecs, or a new version of media player.
divx mpeg-4, divx alpha 3.11 should work. -
Those codec's are for AVI not VCD Mpeg, visit Microsoft update and install the new Media Player.
vcd mpegs are mpeg1 which should play on any computer...
Is this a cd image file (e.g. .bin, .cue, .toc, ...)?...
If so use daemon tools to mount the image as a virtual vcd and play it using wmplayerBig_Jit -
ShouldOriginally Posted by Big_Jit
They dont as standard, any MS media player update will fix this problem.
Copy/Play HDDVD's from your hard drive
By joepic in forum Blu-ray RippingReplies: 20Last Post: 31st Jan 2012, 05:31 -
How to play HD Video from Hard Drive to Bluray
By jbitakis in forum Authoring (Blu-ray)Replies: 51Last Post: 14th Nov 2011, 16:43 -
What video formats my videos on hard drive should be so my TV would play it
By Panasonic10 in forum Video ConversionReplies: 3Last Post: 9th Dec 2010, 20:25 -
Play a DVD folder from a hard drive on your TV (without using a computer)?
By coxanhvn in forum Newbie / General discussionsReplies: 15Last Post: 10th May 2010, 16:11 -
DVD player to play Divx through Hard Drive
By craigwojo in forum DVD & Blu-ray PlayersReplies: 8Last Post: 20th Jan 2010, 10:16
