i go through all the process as described in all guides. it starts converting and goes through the motion. it finishes but when i check the wav file it is not complete??? just tried dragonfly and it only converted 41:00 mins of it. i thought it may have been a bad divx so i tried another film that just converted 39 mins. i have checked all the settings but i cannot find anything . thanks in advance for any advice.
Problem sorted, IT WAS ME!!!!!. i had direct stream enabled in the audio options and not full processing mode!!!!
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
Simple Virtual Dub Problem...
By tetzy in forum EditingReplies: 2Last Post: 22nd Feb 2008, 19:49 -
virtual dub choppy avi
By bigwheels103 in forum Newbie / General discussionsReplies: 2Last Post: 24th Oct 2007, 20:27 -
AVI to DVD w/ Virtual Dub
By hawsonggook in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:58
