Just got my new burner in, it's the plextor 40/12/40...got it pretty cheap...anyhow, I was having trouble getting my bios to reckognize it. Well I got it now, but I'm kind of afraid of changing anything (aka putting my cd-rom back in along side the burner) because for a while my computer wouldn't even boot up because of something I must have done wrong with the jumpers. I have a HD, cd-rom, and burner. Basically if someone could tell me what setup would work the best, it would be greatly appreciated! I've never been good with setting up the jumpers and whatnot....![]()
If it's on the same IDE cable as your HD then it would be your Primary slave so you would need to set the jumper accordingly. If it is on same cable as your existing CD ROM then it is likely to need your jumper to be set to Secondary slave. Normal default out of the box will have a master setting not a slave.
You should see your current assignments during boot up or if you go into BIOS.
A tip: always best to keep CD rom & burner separate from hard disk IDE if possible.
Playback on both primary and secondary display
By mate in forum Software PlayingReplies: 3Last Post: 19th Apr 2010, 12:24 -
Slow Data Transfer from Slave to Master
By jollyjohn in forum ComputerReplies: 15Last Post: 9th Oct 2009, 00:48 -
Need slave function for capturing
By doggyjumper in forum Capturing and VCRReplies: 0Last Post: 25th Sep 2008, 11:06 -
Which Burner for do I set as Master/Slave
By mn072065 in forum DVD & Blu-ray WritersReplies: 12Last Post: 17th Apr 2008, 09:46 -
"Master" Master Audio Volume Control?
By Soopafresh in forum ComputerReplies: 1Last Post: 19th Mar 2008, 08:57
