I am trying to make a VCD and the avi videosource is widescreen. The res is I guess 720x576. I go to TMPG and I can get the aspect right, but it locks the res at 320x240. I went to check out the mpg before I burned it and with the resolution so small, it obviously look terrible when I blow it up. How do I fix this problem because the original res was much nicer? Or will it simply play at the 1x res on the tv and look fine once its burned?
VCD resolution IS 352x240(288). If you want VCD that's what you get. 8) Read http://www.vcdhelp.com/vcd.htm
Resolution Question
By killerteengohan in forum DVD RippingReplies: 14Last Post: 9th Aug 2011, 23:00 -
PC to TV screen resolution question
By majel in forum DVB / IPTVReplies: 15Last Post: 28th Jun 2010, 11:22 -
Video Resolution Question
By mohawkcr in forum Video ConversionReplies: 10Last Post: 22nd Apr 2010, 22:40 -
DLP Resolution Question ?????
By ofield1 in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2008, 20:44 -
Newbie question: 480i resolution
By Direwolf in forum DVD & Blu-ray RecordersReplies: 1Last Post: 10th May 2007, 13:06
