got a couple of svcd movies from a friend that works fine on the dvd player. im trying to burn me a copy using the same brand of disks. im copying the disk to the hard drive than using nero to pull the mpeg file to make a new svcd. The copy works great on the computer but I cant get it to work on the dvd its realy broken up. Anyone know a better way to copy the disk??? this is the closest ive got to getting it to work just seems that im missing something. thanks for any help
Nero is no good for multitrack images like SVCD usually is. ISO is also not very good (or crap I should say). get yourself a copy of CDRWIN and create a bin/cue from the original and then burn the bin/cue like you normally would. should be exactly what your friend has.
Clone CD will "clone" disks, so u have an exact image(except some encoded games)
Adaptec also works, "cd copy" -
If all else fails - try burning a Nero Image to disk (.nrg file) from within Nero - use the CD copy option and select to keep image file - then use Nero to burn this directly to the new CDR.
I've used this before and it works fine for all formats (I've tried SVCD,VCD,ISO etc - haven't tried DVD..)
TeeeRex
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
Coping VHSC tapes to DVD+r, lost content due to white noise
By PanMan in forum Capturing and VCRReplies: 2Last Post: 25th Sep 2008, 20:54 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27
