I do exacly as it is showed in "how to make svcd with nero" -guide but when i click write, it starts to make image file. Even if i open that image file that has been created and try to burn it, it starts to make new image file. So is the problem because im trying to burn two(both mpg's are about 350meg and the cd is 700meg) mpeg2 files or what and how i suppose to burn them?
You did choose 'make new VCD' under nero right? Also did you select a CDR for nero to use? It sounds like you might have set 'make image files/HD' as your default CDR. Run Nero and make sure it's detected your CDR.
avi to mpeg2 burning problem
By deadwreck09 in forum MacReplies: 4Last Post: 19th Nov 2009, 13:17 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Nero InfoTool mis-identifying MPEG2 as MPEG1?
By justin81 in forum Newbie / General discussionsReplies: 0Last Post: 21st Mar 2008, 10:00 -
NERO burning help
By efiste2 in forum Authoring (DVD)Replies: 6Last Post: 11th Jan 2008, 08:35 -
Burning mpeg2 to DVD-9 with nero 6
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 03:11
