Which vcd/svcd burner is the best?
I downloaded some moives put them through The TMPGEnc software program. Now what do I do? HELP!!!
NERO
... 'nuff said
-ChrisScience is everything we understand well enough to explain to a computer. Art is everything else. - David Knuth -
Nero is FAR FAR away from being the best S/VCD authoring/burning program.
Nero is okay for simple multitrack S/VCDs but it is hopeless for menus or anything else.
The best authoring/burning package would probably be VCDEasy (a GUI for both VCDImager which is the best/most flexible/powerful S/VCD authoring program in existence; and CDRDAO, an open source CUE/BIN burning proggy).
This also happens to be free.
For more info on VCDEasy: http://www.vcdeasy.org
For more info on VCDImager: http://www.vcdimager.org and http://www.vcdimager.org/guides
In terms of commercial programs, VideoPack5 seems pretty good.
Regards.Michael Tam
w: Morsels of Evidence -
So VITUALIS, you're saying that after I download the movie of chioce. Use TMPGEnc to convert to Mpeg than use VCDEASY OR VCDIMAGER (which one), so I can copy them on disk so I can watch the movie on a my DVD?
What would be the best software for authoring DVD? VCD?
I use Studio 7 from Pinnacle for my video editing and I bought a DVD burner. What's best for making slideshows, movies, photo albulm for DVD and/or VCD? Is there such a software or do I need to get a couple to get the work done? - Thanx.We all keep on learning - Even if we don't want to. -
VCDEasy is a GUI (graphical user interface) to VCDImager.Originally Posted by JtQuest
For the beginner, I suggest using a GUI (like VCDEasy) than using VCDImager straight as it is simply easier.
Regards.Michael Tam
AVOID Roxio EZCD Creator if you are running Windows XP. Yes, AVOID it at any cost or you'll regret. You will end up reinstalling your XP. You'll bump into something irrecoverbable such as losing your CD-ROM drivers that not able to be fixed by anything so far. Roxio is working on it and hopefully they will solve this ridiculous problem someday.
P.S.: Updating to 5.1 won't help also. Beware! Or Regret.
